Prim/tambura/tamburitza anyone got a plan? http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=49736 |
Author: | Dave Livermore [ Thu Sep 21, 2017 9:34 pm ] |
Post subject: | Prim/tambura/tamburitza anyone got a plan? |
Someone approached me about building one of these for them. Having trouble finding a plan (or even a picture of the back) Dimensions would be useful. Any help appreciated. Thanks, Dave |
Author: | truckjohn [ Thu Sep 21, 2017 11:25 pm ] |
Post subject: | Re: Prim/tambura/tamburitza anyone got a plan? |
Isn't that one of those things that has a gourd back? Looks like a birdhouse gourd would do the trick.. It looks like the way it works is similar to the Russian Balalaika or Domra. A long neck, 2 or 3 strings, and a roundy back... I bet the good ones are super loud. Here's a blog that shows some of the process. http://punemusiccircle.blogspot.com/201 ... 6.html?m=1 and another - looks like more sitar based... Probably enough similarity where you get the idea. http://www.hacklemanshop.com/luthiers-article.html |
Author: | ernie [ Fri Sep 22, 2017 4:48 pm ] |
Have you tried the G.A.L plans ?? |
Author: | gxs [ Sun Sep 24, 2017 4:13 pm ] |
I have a prima. The back is flat. The top is flat. I think the Yugo folk instuments are flat back. They are derivative from bowl backed instruments but are flat backed, maybe a slight arch in the large ones. Mine was of... Soviet Bloc era quality (so I did some work on it) from one if the former Yugo republics - probably Croatia Body Width 5.5" Length 8.75" Rim 1 5/16" - no taper stem to stern Spruce top Pear or Cherry back and sides White binding Floating arch top style bridge 5 strings (1&2 are tuned in unison) Scale length 15" (They can vary there are at least 3 sizes of prima, not counting the other larger Yugo folk instuments, maybe D, E, or G tuning, I can't remember. I think ~15" is the shorter scale/highest pitch. Nut width 1 1/8" FB width at the body joint 1 7/16" Headstock angle appears to be ~ 10 degrees maybe a little less. The neck is usually fruit wood. Mine is maple with a fruitwood fb that was dyed black and I laid a slab of mahogany over it when refretting to try to mellow the tone bit... It may have worked ![]() It originally had nails to hang the strings and a copper plate on the rim to keep them from digging into the top. I added a mando tail piece, and use mando loop end strings. They usually fret them way up into the body. I stopped at the body joint when I refretted since my fingers are too big to play up there, but that is not traditional. Usually they would go up the fb extension. The ~flower/tulip inlay on the top is (I think) traditionally walnut. Regards, GS Sent from my SM-G950U1 using Tapatalk |
Author: | gxs [ Sun Sep 24, 2017 4:15 pm ] |
gxs wrote: I have a prima. The back is flat. The top is flat. I think the Yugo folk instuments are flat back. They are derivative from bowl backed instruments but are flat backed, maybe a slight arch in the large ones. Here is a pic. Mine was of... Soviet Bloc era quality (so I did some work on it) from one if the former Yugo republics - probably Croatia Body Width 5.5" Length 8.75" Rim 1 5/16" - no taper stem to stern Spruce top Pear or Cherry back and sides White binding Floating arch top style bridge 5 strings (1&2 are tuned in unison) Scale length 15" (They can vary there are at least 3 sizes of prima, not counting the other larger Yugo folk instuments, maybe D, E, or G tuning, I can't remember. I think ~15" is the shorter scale/highest pitch. Nut width 1 1/8" FB width at the body joint 1 7/16" Headstock angle appears to be ~ 10 degrees maybe a little less. The neck is usually fruit wood. Mine is maple with a fruitwood fb that was dyed black and I laid a slab of mahogany over it when refretting to try to mellow the tone bit... It may have worked ![]() It originally had nails to hang the strings and a copper plate on the rim to keep them from digging into the top. I added a mando tail piece, and use mando loop end strings. They usually fret them way up into the body. I stopped at the body joint when I refretted since my fingers are too big to play up there, but that is not traditional. Usually they would go up the fb extension. The ~flower/tulip inlay on the top is (I think) traditionally walnut. Regards, GS Sent from my SM-G950U1 using Tapatalk ![]() Sent from my SM-G950U1 using Tapatalk |
Author: | gxs [ Sun Sep 24, 2017 4:18 pm ] |
truckjohn wrote: Isn't that one of those things that has a gourd back? Looks like a birdhouse gourd would do the trick.. It looks like the way it works is similar to the Russian Balalaika or Domra. A long neck, 2 or 3 strings, and a roundy back... I bet the good ones are super loud. Mine is flatback, and it is super loud. A bit shrill, I think it is one of those instuments that is painful to hear someone learn. Like breaking glass. Here's a blog that shows some of the process. http://punemusiccircle.blogspot.com/201 ... 6.html?m=1 and another - looks like more sitar based... Probably enough similarity where you get the idea. http://www.hacklemanshop.com/luthiers-article.html ![]() Sent from my SM-G950U1 using Tapatalk |
Author: | Dave Livermore [ Sun Sep 24, 2017 8:28 pm ] |
Thanks so much for the replies! This helps a lot. Dave |
Author: | junior [ Mon Mar 04, 2019 5:13 pm ] |
The definitive study on the tambura / tamburitza is a book by Dusan Brankov, Tambura. It contains the plans for all the instruments in the tambura family, starting with the bizernica (prim) all the way to celo... |
Author: | whiskywill [ Tue Mar 12, 2019 11:59 am ] |
I haven't checked but there might be something on here. http://www.atlasofpluckedinstruments.com/europe.htm |
